my phone bill is higher than normal
I've just received my second bill and it's 59 pound instead of 36.99, it says it's a monthly reccuring charge what is this, my bill isn't supposed to be that high
  • 12258 replies
  • July 11, 2023
Okay @Benjones234, have you changed your payment date?
  • July 11, 2023
Yeah will it just be one 20 pound charge?
  • 12258 replies
  • July 11, 2023
In most cases, everything reverts to normal once the date change has been through one billing cycle.
  • 7962 replies
  • July 13, 2023
Hello @Benjones234,
This is often down to one of few factors:
  • You’ve changed your payment date
  • You recently upgraded or changed your plan/tariff
  • You have out of plan usage for exceeding allowances or roaming or international calls
  • You have purchased add-ons
The bill should be able to provide a full breakdown so you’ll get an idea of what these charges are for.
If the bill is only for line rental, check the period that this covers.
Normally a bill covers 1-month in advance.
Bills following a Direct Debit date change may cover a bigger period due to moving the bill date which is normal (and advised when submitting the request).
Bills following a plan change or upgrade will provide a credit for period of time from the date you upgraded/changed and then re-bill you the new amount. This can cause the bill to be higher or lower depending on the plan you changed to.
