Anyone else experiencing really slow network connection today.
I have 4g and the signal is good quality. Just really laggy.
I'm away for the weekend so maybe just the location, though i did check the coverage map on the ID website. That showed good quality coverage.
Just curious guys if anyone else is laggy too?
Network connection slow today?
Best answer by Mohammed
Hey @Adzdalton ,
As you may already be aware, we have a coverage checker on https://www.idmobile.co.uk/help-and-advice/uk-coverage-checker
It's worth checking this as there may be a coverage issue in the area affecting 4G coverage.
If you're away from home, simply enter the postcode you're currently in for the coverage.
If you're in a city centre, it's possible that the mast is congested due to high traffic and can cause the speeds to drop slightly.
View originalAs you may already be aware, we have a coverage checker on https://www.idmobile.co.uk/help-and-advice/uk-coverage-checker
