network not available for voice calls
  • December 17, 2020
  • 150 views
Phil The Rope
Unable to make calls RG41 5AT
Best answer by Phil The Rope
All that does is help people choose a network that’s allegedly good in their area - it’s not a “live status”, i.e. it doesn’t report outages.
Network now seems to be working, but it was unavailable for a few hours earlier.
  • December 17, 2020
Have you checked network coverage. You are facing problem at one place only or every where. Use this to check network coverage.
Phil The Rope
  • December 17, 2020
  • December 18, 2020
You get incoming call. Do you have balance in account.
Change calling apps and try to make call.
  • 7962 replies
  • December 22, 2020
Hello @Phil The Rope,
Glad to hear that the network is working fine now.
There can be outages or planned maintenance from time to time.
The checker should indicate if there’s any issues, you can try using the one on the Three UK website which may update right away.
