network signal is poor - calls drop out
I have had every call in my flat drop out. I need a stronger signal - I have only been with ID for a month but the service is not good enough
Best answer by Lauren K
Hi @Coll888, welcome to the community. However, I’m sorry to hear you’re experiencing issues with your coverage.
Coverage can vary per area and there are many factors that can impact this. It’s possible that 3UK is not as strong in your local area which could be why the coverage is affected. If it’s occurring everywhere you go, the issue points more likely to a handset or SIM fault. It’s also worthwhile checking if there are any outages or planned work in your post code:
Check your network coverage | Support | Three
If you’re in a poor coverage area, it’s worth noting that we offer 30-day returns on all contracts purchased from iD Mobile directly and 14-days if bought from Carphone Warehouse.
If you’d like us to take a closer look into the coverage issues you’re having, just let us know and we’ll be happy to send you a PM.
-Lauren
  • 12550 replies
  • April 23, 2024
Okay @Coll888, have you tried using the iD WiFi Calling service in your flat?
You’d need a Wi-Fi network connection in your flat, to use WiFi Calling.
Living in my mobile not-spot, I rely on WiFi Calling at home.
  • April 23, 2024
Yes I have tried that - my phone was set up for WiFi calls. Does ID not have a customer services? How do I sort this out?? Thanks
  • 12550 replies
  • April 23, 2024
Unfortunately @Coll888, iD Mobile don’t provide a telephone support helpline.
Their customer service is by online Live Chat, or through their social media pages, using Facebook Messenger or X (formerly Twitter).
The advisers work until 8pm on weekdays.
The iD Mobile WiFi Calling service has worked well for me in my location.
Lauren K
Forum|alt.badge.img+19
  • 479 replies
  • April 27, 2024
-Lauren
  • April 27, 2024
Yes I would like a personal message as I can’t get hold of customer services as I don’t know my PIN number
thanks
  • 8584 replies
  • May 1, 2024
Hi @Coll888
Brokenandbusted
Hmmmmm.....coverage map for 4g for my area misleadingly shows full indoor / outdoor coverage but rarely able to make any calls over network
All very frustrating and misleading
I'd not alone , all networks are scamming us with rubbish signal strengths
Tried WiFi calling with my excellent home WiFi but phone only occasionally managed to access it despite correct settingd
  • 12550 replies
  • May 3, 2024
The coverage map is only a theoretical prediction of the signal reception at any given location, and actual reception might be better or worse than predicted.
The iD WiFi Calling service is a good indoor alternative, but your handset needs an option to have Wi-Fi Calling as being preferred, for this to work reliably.
  • June 2, 2024
Started contract with ID and calls keep cutting out, no signal in our home at all even though the map says it is in a good area. Bought phone on Wednesday last week, from mobiles.com and the service is awful having to rely in wifi signal alone.
  • 8256 replies
  • June 7, 2024
Hi @Michaelm1983,
Have you checked the network status checker to see if there are any issues in the area?
I would also advise testing the SIM in a different handset.
  • June 7, 2024
Yes did try in another phone, still no signal, tried with replacement sim, still no signal. Check area, still nothing. Now coming away from from the id network as not known anything like it and was able to cancel in the cooling off period. It's like going back to the days of wired connections.
  • 5495 replies
  • June 19, 2024
Hey @Michaelm1983, we’re sorry to hear that and sorry it didn’t work out with us, and we wish you all the best.
