No 4G Signal
  • December 11, 2018
  • 1838 views
friendlyJai
I am currently on Giffgaff and decided to try out the ID Network as seemed like a good deal. I went on their coverage checker and put in my post code to make sure I can get 4G in my area and said I could.
I put my new Sim card in today and also used their website to send the correct settings according to the make and model of my phone. But I am only getting a H signal and no 4G in my house. On Giffgaff I got the full 4G signal
Is this a problem with a setting or is just not available in my area? If its isn't think I will cancel and stick to Giffgaff
Thanks in advance
James
Best answer by terrywebbs
Welcome to the ID Community,
Put your SIM card into another phone and test your network coverage. This will help you to work out if there is a problem with your phone or the network.
Then check you APN settings are correct for the ID Network.
the following page will be helpful in checking those
https://www.idmobile.co.uk/help-and-advice/get-your-settings
If you have an iphone plug it into tunes and update it, there was a roll out of new carrier network settings recently, this might fix your issue?
terrywebbs
Helpful
  • Helpful
  • 515 replies
  • December 11, 2018
Kevin M
  • 2535 replies
  • December 12, 2018
Some good tips there @terrywebbs
@friendlyJai please let us know how you're getting on, if you are able to pop the iD Mobile SIM in another handset to see how that fairs, then you might be able to help us all identify whether a setting in your phone is causing some conflict here.
Kevin
friendlyJai
  • December 12, 2018
I tested it outside and can get 4G in town. Put I get No Service at all in my gym and with Giffgaff had 4G. So its no good to me. How do I go about cancelling please.
terrywebbs
Helpful
  • Helpful
  • 515 replies
  • December 12, 2018
Sorry to see you go...
The following link will give you all the details you need to cancel
https://www.idmobile.co.uk/help-and-advice/returns-cancellations
