no connection
  • April 18, 2024
  • 24 views
Natalija Petrova
No connection at all what going on. Plus my partner when I am texting him he receives my text from different number no my.
  • April 22, 2024
Hi @Natalija Petrova,
If you are using an iPhone please can you try the below:
If you are using an android please try the below:
Alternatively, you can turn Chat Features/RCS off and test SMS after this.
If you still have issues, please let us know.
