No connection in Jersey
Mo6655335
My phone can't connect to a network in Jersey Channel Islands. I have roaming enabled and have been using my phone there fine until yesterday. Are there any technical issues?
Best answer by Kash M
Hi @Mo6655335,
Have you tried removing the SIM for a few minutes whilst the handset is off?
It may also be worth doing a network reset on the device.
  • March 19, 2024
Hi @Mo6655335,
Mo6655335
  • March 19, 2024
Thanks Kash. It turns out that manually selecting the network makes it connect. For some reason it does not automatically connect to a Jersey network. It's not my phone as I have tried it in another phone
  • 8484 replies
  • March 19, 2024
Hi @Mo6655335
Glad to hear manually selecting a network helped here.
