No phone signal or access to 4G and 5G!
Amyrobbie
I have been with ID mobile for over 2 years and up until recently everything had been fine. For the past 5 days I have completely lost all phone signal! I am also unable to access 4G or 5G. This has happened for a few hours before at most but not 5 days!
My phone is working fine in other ways (connects to wifi, apps work, all hardware is good etc.) but it is making work very challenging. I will have to find a new provider very soon if this isn’t fixed. Does anyone have any ideas of what could be the issue?
Okay @Amyrobbie, your handset might not be approved by iD Mobile for their 4G & 5G network.
See iD approved handsets at https://www.idmobile.co.uk/help-and-advice/approved-handsets
Have you tried:
  1. Turn off handset
  2. Remove SIM card
  3. Wait at least 15-minutes
  4. Insert SIM card
  5. Restart handset
  • 12530 replies
  • May 13, 2024
Are you in the Midlands area where Three UK (the iD network partner) have switched off their 3G network, @Amyrobbie
Amyrobbie
  • May 13, 2024
Hi there, thank you for the response. I am actually! Would this have an effect on phone signal and 4G/5G access?
  • 12530 replies
  • May 13, 2024
Have you tried:
  1. Turn off handset
  2. Remove SIM card
  4. Insert SIM card
  5. Restart handset
