no roaming
Mark Wall
Helpful
Hi, I am in Crete and can get no roaming (only get E no 3G or 4G). This is even though my account and phone both have roaming on and my friends on other networks are getting 4G
any ideas?
Best answer by Mark Wall
Resolved in the end by deleting old provider APN settings and manually loading iD APN. Twitter fee v helpful
  • 12550 replies
  • August 30, 2023
Is this only an issue with your roaming mobile data, or do you have problems with calls and texts as well @Mark Wall
Are you using an iPhone or Android device?
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • August 30, 2023
Only when roaming all
else fine.
iPhone 13
  • 12550 replies
  • August 30, 2023
You could be suffering because the iD SIM in your iPhone 13 might not pick-up the correct APN settings while roaming in Crete @Mark Wall
Unfortunately, iD have issues with allowing iPhone devices access to edit the APN settings for MOBILE DATA.
A potential work-around is described by @Mohammed in his post in the following topic.
  • 8584 replies
  • August 31, 2023
Hi @Mark Wall
Have you tried resetting network settings on the device?
Have you tried manually connection to a network instead of automatic network selection?
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • August 31, 2023
Yes tried both with no success sadly.
  • 8584 replies
  • September 1, 2023
Hi @Mark Wall
Okay, are you able to see and change your APN settings?
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 1, 2023
Not that I can see, no. Only cellular data option and that just lists carriers.
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 1, 2023
One of the customer service team told me that I couldn’t access data as I “was near the sea” and I needed to increase my cap - even though I was nowhere near my cap. A second person was more helpful but then said he had to refer to technical team who would contact me. But they haven’t yet.
  • 12550 replies
  • September 1, 2023
Cellular or Mobile @Mark Wall
Just checking, because typically you’d only see Cellular used in Settings on a US iPhone.
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 1, 2023
Yes, I was surprised.  Under settings I have airplane mode, wi fi, Bluetooth, personal hotspot and cellular.   Under cellular I have cellular data and cellular options. It’s a Uk bought iPhone 13.
  • 12550 replies
  • September 1, 2023
That’s weird @Mark Wall
I’ve got an iPhone 13 via UK retail channel, which is running iOS 16.6.
On my iPhone device the options displayed are: “Airplane Mode”, “Wi-Fi”, “Bluetooth”, “Mobile Data”, and “Personal Hotspot”.
Under the “Mobile Data” option, I’m shown the following options: “Mobile Data”, “Mobile Data Options”, and “Personal Hotspot”.
My iPhone 13 has the “Model Number” value “MLMN3LL/A”.
Perhaps iD are using incorrect carrier settings for iPhone devices?
Are you using iOS 16.6?
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 1, 2023
Yes I’m in 16.6
  • 12550 replies
  • September 1, 2023
Weird - UK models should be using “Mobile Data”, not “Cellular”.
All the Apple GB online support articles refer to “Mobile Data” - what iPhone 13 model have you got?
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 1, 2023
Iphone13 mini on IOS 16.6
  • 12550 replies
  • September 1, 2023
Okay @Mark Wall, I think that’s the “Model Name”.
You should be able to find the “Model Number” in Settings > General > About
I’m wondering if your iPhone 13 is set to use English (US) instead of English (UK), or if the Region setting is not “United Kingdom”.
The options are found under Settings > General > Language & Region.
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 1, 2023
Thanks. MLK43B/A is model number. I can’t find language and regional option but it does say carrier is iD54?
  • 12550 replies
  • September 1, 2023
Try Settings > General, then scroll down to Language & Region.
If you tap Language & Region, you should be able access the options to choose the language (English UK) and region.
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 1, 2023
Sorted thank you. Now changed from US to UK. How do I now review APN?
  • 12550 replies
  • September 1, 2023
It should be accessible from Settings > Mobile Data, then scroll down to Mobile Data Network.
If you tap Mobile Data Network, you should find the APN in MOBILE DATA.
The correct value is “id” (in lowercase).
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 2, 2023
Thanks - when I go into mobile data I only have the following options;
Mobile data (on/off)
mobile data optins: data roamoing on/off, voice and data (5G auto), data mode (standard), limnit IP address tracking - on
personal hotspot
ID selection : auto, vodafone, Wind GR, cosmote
wi fi calling - on
network provider services - 447782333123
SIM Pin
then a list of how kuch mobile data I’ve used in the last period on different apps
  • 12550 replies
  • September 2, 2023
Scroll down to Mobile Data Network.
When you tap Mobile Data Network, you’ll see the APN settings.
If Mobile Data is OFF, the Mobile Data Network option is not available.
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 3, 2023
Thanks everyone - all v helpful.
in the end I Had to delete previous providers APN setting and manually download iD APN settings. The iD Twitter response was v helpful. The customer service live chat was pretty poor.
  • 8256 replies
  • September 4, 2023
Hi @Mark Wall,
Glad to hear that this is resolved.
  • 12550 replies
  • September 4, 2023
Hey @Kash, not sure the issue has been resolved.
The OP by @Mark Wall appears to be about not having roaming mobile data in Crete.
Mark Wall
Helpful
  • Helpful
  • 14 replies
  • September 4, 2023
