Changed from Vodafone yesterday the signal on this network is terrible keeps dropping out doesn't matter where I am changed from from 5g 4g 3g auto then on 3g 2g and lte works OK when I'm on WiFi wish I'd never changed
no signal
Best answer by WelshPaul
iD Mobile are currently experiencing a technical issue that means some customers may be unable to make or receive calls. Please refer to the link below for the latest updates:
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
