NOT ALLOWING ME TO UPGRADE
Harry C Howe
I’ve finished my 2 year term and now want to upgrade however the app doesn’t let me view all the possible upgrade deals!
Been on the website as well but it just tells you to login and then does the same thing!
Best answer by Lauren
Hi @Harry C Howe, the iD app/your plan online should show all of your available upgrade options. However, you can also call the sales team direct to discuss.
Their number is 0207 1391 397. They’re open from 9am-6pm.
-Lauren
  • 12408 replies
  • April 22, 2024
You can also discuss an upgrade with the iD sales team - call 0800 049 0250, @Harry C Howe.
  • Helpful
  • 12 replies
  • April 24, 2024
Hi, you can also upgrade via Carphone Warehouse website which I found easier than trying to speak to someone on the phone.
Select ‘Upgrades’ from the main page, enter your ID information and it will check your eligibility and show you all the relevant deals available.
Hope that helps
Lauren
Forum|alt.badge.img+19
  • 479 replies
  • April 27, 2024
-Lauren
