i am having problems with receiving and making calls, one day it will be ok and then can’t do either for several days, i have rebooted my phone several times, all the settings are the same, is this an ID network problem or something else?
Ron
Ron
Best answer by Kash M
It sounds like it may your handset settings.
Have you tried to enable 4G and Volte then disable 3G.
The Community post below may help.
