Not receiving incoming text or calls
Swapped to iD mobile bringing my old number from giffgaff. (also new phone iPhone 12 to 15)
Message received 11 am Monday 25th saying all swapped over.
Since then I can call and text out ok
But can’t receive calls or texts (plus won't connect my original number back to iMessage or FaceTime)
I have turned off and on, reset network, turned off/on iMessage and FaceTime! Done full back up and re downloaded whole phone! Reboots and still not working
Anyone that can see information on the Port process and any issues from that side of things…
Only other answer I see is wait 72 hours and it may sort itself.
Its been ridiculous because I’ve missed doctors phone calls and can’t set anything up as everything needs to send a code to your mobile (which obviously isn’t receiving)
Old/ interim number that came with the sim no longer works
Basically just need to see if the Port has been completed properly but who or how can I get this looked at??
Best answer by preedygood
So just an update……
Finally sorted after 3 weeks and phone working ok.
If you have similar issue state that the number port was split… this got it escalated from ID mobile tech team (who just kept saying everything looked ok) to Threes’s tech team who still took a week to resolve but got there in the end :)
  • 12408 replies
  • September 27, 2023
If you can’t receive calls and text messages (by SMS), it sounds like something’s gone wrong with your switching request @preedygood.
Posting in this forum will be the slowest way of talking to iD staff.
For timely assistance with your iD account and network connection perhaps try one of the following:-
  • iD Live Chat
  • Facebook Messenger
  • X (Twitter) DM
I’m having this issue too, I swapped over to ID in June and everything worked fine. Put the aim in my new iPhone 15 and iMessage and FaceTime won’t activate. I am receiving cellular calls and texts but extremely frustrating
  • 8408 replies
  • September 29, 2023
Hi @preedygood & @ahfraz
I’d recommend trying the following;
  • October 3, 2023
Hi, so update…. have tried all reset options as mentioned above plus other. network reset, phone reset, sim in different phone. Have now had 3 different sim and reactivated. Tech telling me through CS that all ok but clearly isn’t! This is a full week now since original port…. I can not access anything whatsapp, banking, FB as all need text verification.
How to I get this prioritised…??? This isn’t acceptable I need my phone to talk to my children.
Someone please help
Is there a tech support number I can ring instead, silly doing chinese whispers through CS
  • 12408 replies
  • October 3, 2023
Unfortunately iD don’t have a telephone support helpline option @preedygood
Your original post said you couldn’t receive any calls, nor text messages.
If so, sounds like your port wasn’t completed properly, or there’s a problem with your iD network account.
If getting assistance using Live Chat, Facebook Messenger, or X (Twitter) DM isn’t working, perhaps consider transferring your number to another service provider.
  • October 4, 2023
Hi @preedygood,
We hope that you managed to get some help from the information that @andewhite provided.
If you still require assistance, please get back to us here and we can PM you.
  • October 12, 2023
So just an update……
  • October 16, 2023
Hi @preedygood,
Glad to hear that your issue is resolved.
  • January 17, 2024
I sent my PAC code to ID before setting up a profile on the app.
Since putting my new ID sim in my phone I can’t receive calls or texts but I can send them.
I haven’t even received a welcome message from ID mobile.
I also can’t set up the app using the phone number sent to me via email
  • January 21, 2024
Hi @Harri6402,
I can see that we responded to your other post.
If you require further assistance, please get back to us there.
