Not receiving OTP messages
URGENT
I just switched from Vodafone and I'm not getting important OTP text messages. I tried removing sim card, switching my phone on and off. Phone calls and ordinary txt messages appear to be okay. I have Apple iPhone 11. Thank you.
Howard Sharp
  • December 15, 2021
I am having exactly the same issue and unable to get on to my santander bank app as unable to register my device. Same with amazon app. Tried restart, taking sim out etc. Google pixel 6 phone.
Howard Sharp
  • December 15, 2021
I am not getting one time passcodes from both my banking app and amazon. Tried removal of sim and reboot of phone. Moved across from Vodafone.
Will
  • 4103 replies
  • December 16, 2021
Hi @Howard Sharp,
Will
  • 3053 replies
  • December 16, 2021
I have seen similar posts on the O2 and Vodafone community forums... All recently ported networks. I wonder if it's part of the porting process and just takes longer to complete (24/48 hours)?
  • December 20, 2021
I have the same issue. I ported 5 days ago and my number is showing correctly in my Iphone Phone settings
Howard Sharp
  • December 20, 2021
Should be resolved when you get a private message from ID admin. Mines ok now . I suspect that a sim refresh does the trick.
  • December 20, 2021
Thanks Howard, I will await their message
  • December 20, 2021
Hi @Ian Stirling ,
Can you try the following;
1) Try turning off iMessage (Settings > Messages)
2) then restart your phone (by pressing and holding the on/off button)
3) tap Settings > Phone > My Number and confirm that it is correct.
4) If it is not correct, please enter the correct number)
5) then turn iMessage back to On (Settings > Messages)
6) go to Settings > Messages > Send & Receive and see if the correct number is displayed under “Start new conversations from:"
  • December 20, 2021
Thanks Kash.
I already tried this, in my message I said that my number is correctly showing on phone. It is also correct on messages
  • December 20, 2021
Kash, what else can I do to fix?
  • December 21, 2021
@Ian Stirling,
  • 6 replies
  • April 21, 2022
I am having the same issues mentioned here.
i have done the deactivate I message and out back on, then phone on and off for an hour etc. tried everything mentioned, it’s a brand new phone so i believe  the issue is with the network and not my i phone.
  • 12408 replies
  • April 21, 2022
Hello @Lj2022,
This issue seems to occur more frequently with number ports from Vodafone to iD, judging by posts to this forum.
Anyway, the “Not receiving OTP messages” post sounds like a similar problem, which @StuartGlu has solved by re-registering his mobile number with the senders.
Good luck.
  • 6 replies
  • April 21, 2022
Hi @andewhite  Thanks for getting back to me 👍
I have tried what sorted @StuartGlu ’s issue out and I’m still unresolved. I’ve probably got 5-8 app’s/accounts I can’t access as they need an OTP code, HMRC, gmail, DPD, klarna, other banking apps. I have tried to raise the issue on live chat with ID but I haven’t really got anywhere with that.
  • April 27, 2022
@Lj2022,
Did the Live Chat Team raise this to our Tech Team for you?
