Not receiving SMS from italian number when in UK and when in EU
I am not receiving SMS from an italian number when I am in UK and when I am EU.
I can receive SMS from UK numbers when in UK and when abroad, I can receive and make calls to italian numbers.
I have a pay montly plan, in manage iD services I have International on, Roamin on, Premium on,
Data 100GB, Minutes Unlimited ,Texts Unlimited.
If I put an italian sim in the smartphome, I can receive and send SMS text.
I tested with one sim in the smartphone and with dual sim, the issue is always there.
I have a Galaxy S24 ultra.
Any suggestion?
Kind Regards
emax69 wrote:
It is not just from one numenber,but any number, I have teested few
You’ll probably need the iD Mobile tech support dept to look into this issue, @emax69
Good luck.
  • 12461 replies
  • May 16, 2024
Perhaps the person in Italy sending you an SMS, which you don’t receive, has omitted the +44 prefix for your UK mobile number, @emax69.
  • May 16, 2024
I tested with friends that have the number with the prefix,they can call me, I also don’t receive OTP messages from italian websites, they used to work before switching to iD. I also have an italian number on another smartphone that I used to test.
  • 12461 replies
  • May 16, 2024
Okay @emax69, sounds like there might be some network routing issues, following your switch to iD Mobile. When did you switch?
  • May 17, 2024
It was two years ago, but I noticed it few months ago when I needed an OTG already setup on a website before the switch.
  • May 17, 2024
*OTP not OTG
  • 12461 replies
  • May 17, 2024
Can the one problem Italian number call your UK mobile, @emax69?
Have you blocked the Italian number on your phone?
  • May 17, 2024
  • 12461 replies
  • May 17, 2024
Good luck.
  • May 18, 2024
what is the best way to contact them?
