Not receiving texts from numbers.
I'm not receiving texts from all numbers that have tried, recently ported number in without any other apparent problems.
I text them, but no texting reply, when I've called them they advise that they replied.
Any useful info !
Regards
Colin
EACPD02 wrote:
Thanks for that.
However my iPhone was on a corporate account and I believe I had no control over it
Have you tried Apple’s online self-service to unlink your mobile number from your ‘old’ corporate iPhone, @EACPD02
Do this online at https://selfsolve.apple.com/deregister-imessage/.
Scroll down for option called “No longer have your iPhone?”.
  • 12459 replies
  • May 3, 2024
Have you tried a NETWORK RESET on your handset, @EACPD02
The handset user guide should explain how to do this.
  • May 3, 2024
I've read that but reluctant to.
Now done and see what happens. 👍
  • May 4, 2024
Hi @EACPD02,
I hope that your issue is resolved.
  • May 4, 2024
As far as I know it's not resolved.
It not reliable situation to be in , as texts should be reliable to receive as well as send.
I would like more investigation.
Tom B
  • 8434 replies
  • May 6, 2024
Hi @EACPD02
Okay, is this issue all numbers?
On your previous device, have you switched off RCS/iMessage?
  • May 6, 2024
Hi.
My previous device was a corporate iiphone 12,as I worked for BT , it just used text message and not rcs, I've turned of rcs , but you don't really know it's happening unless you speak with someone you've texted.
When I had the iPhone one person I know stopped receiving my texts from tha, now I've ported my number across, they're receiving them now.
On this I've at least 5 I'm not receiving them from and there's not a common factor.
It disconcerting as I may miss something important
Tom B
  • 8434 replies
  • May 9, 2024
Hi @EACPD02
Okay, you may need to disconnect iMessage from your number if you are no longer using an iPhone, this can be done via your Apple account on their website.
  • May 9, 2024
Thanks for that.
  • 12459 replies
  • May 9, 2024
EACPD02 wrote:
Thanks for that.
  • May 9, 2024
Well that a wonderful bit of information that I would have had no idea of.
I've filled it in and we'll see what happens.
Many thanks
  • May 13, 2024
Hi @EACPD02,
I hope the advice that @andewhite provided has resolved your issue.
