number won't switch even on iphone settings
Hey,
transferred my number over got a text from ID to say it is now transferred.
whent into iPhone-phone settings and try to change it there and it keeps going back to the number I got at the start of the contract
any help?
iPhone 14
three to ID
Best answer by Tom
Hi @Opalstar
I’d recommend the following;
  • 12462 replies
  • May 30, 2024
Have you tried a NETWORK RESET, @Opalstar?
Your iOS user guide explains this reset procedure.
  • 8484 replies
  • June 5, 2024
Hi @Opalstar
