Pac code not accepted
Hi, Just trying to swith my number from Virgin Mobile to ID but my PAC code given to me a couple of days ago won’t work. I have entered all the correct information but just keep getting
“We've tried to process your PAC, but there is an issue with the information you've submitted. Please check that you have provided the correct details and try again.”
WHY is this such a problem ?
  • 12545 replies
  • April 6, 2023
Try entering your SURNAME in CAPITAL letters @TrevInNotts.
  • 6 replies
  • April 8, 2023
NO that don’t work. If I can’t switch I’ll just give up and stay with Virgin
  • 8256 replies
  • April 11, 2023
Hi @TrevInNotts,
Are you still having issues with the port?
If so please let us know here and we will help you our via PM.
Mohammed H
  • 7962 replies
  • April 13, 2023
Hey @TrevInNotts,
Make sure also the transaction number begins with 4.
This is found on your Welcome to iD email.
If you still want to cancel or need help, let us know here.
  • 6 replies
  • April 13, 2023
Mohammed wrote:
Hey @TrevInNotts,
Yes believe it or not I did put the correct transaction number from the email. The system is BROKEN, FIX IT.
Number transferred now so finished.
  • 6 replies
  • April 13, 2023
Kash wrote:
Hi @TrevInNotts,
Well none of the replies were helpful, I sorted out the problem myself so not really going to mark any answer “Most Helpful” because they were not
  • April 13, 2023
TrevInNotts wrote:
Kash wrote:
Hi @TrevInNotts,
Eventually porting request was accepted - used capital letter in surname.
