Phone keeps going to emergency calls only
My phone keeps going to emergency calls only. Never happened with O2 having just changed to iD mobile it's really frustrating especially when trying to keep in touch with Important hospital appointments
Best answer by Kash
Hi @Philipsalt,
I can’t see any issues in the area.
Please can you advise if you have tested the SIM in a different handset?
It may also be worth us sending out a replacement SIM in case the SIM is faulty.
  • 8408 replies
  • March 19, 2024
Hi @Philipsalt
Sorry to hear this, does this happen everywhere or just in certain areas?
Please could you let us know the postcode(s) where this happens?
  • March 19, 2024
I live in ch35ul which is Chester city centre ish but it constantly happens all over it very annoying every time I need to call someone its not working and Sod’s Law when people call me it’s answer phone.  I wouldn’t have changed over if I’d known. Is there any reason for such poor service. ?????
  • March 20, 2024
Hi @Philipsalt,
  • June 17, 2024
Hi, my phone is currently displaying ‘emergency calls only’.
I have only had my phone for 7 days, so its not a great start.
Can I have an update on why this is happening - Post code ML7 4YT
  • 4297 replies
  • July 3, 2024
Hey there @TerryD, we're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know, or contact us via live-chat:
