I have been with ID for 3/4 years. I took out a new new contract last year but this week, I have had trouble receiving calls.i I can make calls out but I can't receive calls in unless they are through messenger or Whatsapp.
phone not receiving calls
Best answer by Kash M
Have you ported your number or is it the same number?
It may be a coverage issue so I would advise to check the network status at the link below:
If there are no issues in the area and the SIM has the same issue in another handset, please let us know and we can PM you.
Log in to the iD Community.
Social Login
