Porting issues
Have a issue with porting my number over from O2. Its been a week now and still not done. I cannot receive calls from any other network but 3 and texts dont work except I can send them to people on 3 but they cannot send to me. Raised time and again with iD and I even have a complaint number buts still not resolved. Any suggestions as cannot speak to a person
Best answer by Kash
Hi @Steveb999,
It sounds like you may have a split port which we will need to escalate to the Technical Team.
Have the Complaints Team been in touch with you since?
If not we can drop you a PM to assist further, simply get back to us here to let us know.
  • May 30, 2024
Hi @Steveb999,
  • September 7, 2024
Kash wrote:
  • September 7, 2024
I have issues porting. I ring some people and my regular number comes up and at other times the number that Id mobile provided comes up. That also happens when receiving calls. Some come through to my phone whereas some don’t come through at all and says my phone is turned off. Please can this be resolved!
  • 4228 replies
  • September 10, 2024
Hey there @DanWilson90, welcome to Community!
Please try the following for whichever type of phone you have:
For iPhone:
For Android:
Alternatively, you can turn Chat Features/RCS off and test SMS after this
  • October 25, 2024
I recently left I'd as the coverage is poor in the area, I requested my PAC code and did the port to Lyca mobile ever since I can not receive SMS messages and can't make voice calls to some numbers (RCS messaging and internet seems ok and people seem to be able to call me) Have been told its a porting issue and I need to report it to the provider i have just left - i have reported it to Lyca mobile but 3 days in and no updates or progress - please help have health issues and not sure I am getting messages through from Doctor so it's pretty urgent
Forum|alt.badge.img+21
  • 2245 replies
  • October 28, 2024
Hello @Robert Brind
We are sorry to hear you are experiencing issues following the port of your number.
Once the port is completed from our side, we are not able to run diagnostic checks on issues you may be facing as this will need to be completed by your new provider.
We would however recommend trying the following steps to see if they help.
For iPhone:
For Android:
Nat
