problem with txts and calls
  • December 21, 2021
  • 24 views
Hi I am not able to  receive or send txt messages. Also sometimes unable to receive calls or they end off when it says I have signal.
Please help thank you
  • 8256 replies
  • December 21, 2021
Hi @Emma Whitfield ,
How long have you experienced this issue for?
You can check the coverage and if there are any issues in your area.
Also could you try the SIM in a different handset and let us know if that makes a difference?
  • December 21, 2021
About two weeks. It's not coverage as I have been out and about, I have also been able to recieve txts at home before then. I know of two people who have been trying to contact me over txt and I haven't recieved anything. I also tried sending a txt and again nothing.
  • 8256 replies
  • December 22, 2021
@Emma Whitfield,
Can I ask which handset you are using?
If it’s an iPhone please try the below:
1)    Turn off iMessage (Settings > Messages)
2)    Restart your phone (by pressing and holding the on/off button)
3)    Tap Settings > Phone > My Number and confirm that it is correct.
4)    If it is not correct, please enter the correct number
5)    Turn iMessage back to On (Settings > Messages)
6)    Finally, go to Settings > Messages > Send & Receive and see if the correct number is displayed under “Start new conversations from:”.
