replacement SIM can i keep my same number with ID i?
  • September 25, 2024
  • 218 views
Nightmare with phone and normal ID SIM not working after trying to install airalo E SIM for travel abroad. Have tired everything apart from factory reset. If I get a replacement SIM from ID ( alreqdy have plan) does it keep my same number automatically as with same provider ? Thanks
And if anyone can advise on getting rid of eSIM which refuses to remove from my A54 5g that would be fab.
A replacement iD SIM would use your current number once activated, @SandyR.
  • 12353 replies
  • September 26, 2024
Many thanks for your advice.
  • October 1, 2024
Hi @SandyR,
I hope that your issue is resolved.
