Roaming
I’ve went through all of the advice for how to make my roaming work while abroad and none of it has worked. I don’t understand what else I am meant to do. I’m alone abroad so need data available, if someone could get back to me asap with how to fix this issue it would be appreciated.
  • 12408 replies
  • August 17, 2023
Whereabouts are you roaming @niamhmack.x?
Not all overseas destinations are included for roaming with your UK plan calls, texts, and data allowances - what advice have you followed @niamhmack.x?
If mobile data isn’t working, perhaps you could try connecting to Wi-Fi networks, while you’re getting your roaming mobile data fixed.
  • August 17, 2023
I’m in Spain, which is supposed to be included in my roaming.
I’ve turned my phone off and on again. Turned my roaming off and on again in both my phone settings and on the id mobile app. I’ve tried connecting to the network manually. I’ve made sure that my network is under id mobile and then one of the providers for Spain.
This is the advice provided on the help hub and I’ve used it all.
Luckily I can connect to hotel Wi-Fi for free but I really need this issue sorting asap.
  • 12408 replies
  • August 17, 2023
Okay @niamhmack.x, sometimes the APN settings aren’t set correctly when you’re roaming.
Below are the APN settings required for mobile data to work:
  • August 17, 2023
I don’t have an APN setting on my phone.
  • 12408 replies
  • August 17, 2023
Are you using an iPhone, or Android handset @niamhmack.x?
If you’ve got an iPhone, then unfortunately the procedure for setting the APN values is complicated and unreliable because iD have got issues with this settings option in iOS - as per the post by @Tom from iD Mobile:
  • August 17, 2023
Yes I have a iPhone.
Can you let me know what I am supposed to do then??
  • 12408 replies
  • August 17, 2023
The procedure that sometimes works in this situation is described in the following forum post:
https://community.idmobile.co.uk/roaming-international-48/roaming-data-stopped-working-italy-55107?postid=145506#post145506
  • 8408 replies
  • August 18, 2023
Hi @niamhmack.x
It may be worth checking the above forum post, resetting your network settings or putting your SIM card in another device if possible.
