roaming fair usage
Lee Pearce
I have a 120gb data plan. How much fair usage data will I have?
  • 12380 replies
  • July 11, 2023
Okay @Lee Pearce, you can find this out online at:
You can’t use all of your UK data allowance will roaming in the EU inclusive area, but the amount you can use depends on when you joined iD Mobile. The iD page about their “Fair usage & open data policies” explains it all.
If you’re roaming outside of the EU inclusive area, then you won’t have a roaming data allowance.
Lee Pearce
  • July 11, 2023
Thanks for the info.  That link didn't seem to work for me though.
  • 12380 replies
  • July 11, 2023
Links to the iD Mobile website www.idmobile.co.uk often don’t work if you’re signed-in to the iD Community.
Just sign-out of the iD Community before going to the main iD website @Lee Pearce.
  • 7962 replies
  • July 13, 2023
Hey @Lee Pearce,
This will vary based on when you purchased the plan.
Head to the link above to check this.
You may need to visit via an incognito or private browsing window if the website is not loading or showing URL not supported
