Hi, Id really like to have a sim and an esim with separate numbers one for work and one for personal on the same plan. Ideally I'd like to use the sim in one phone and an esim in the other so I would effectively have two numbers and two devices on one plan. Does anyone know if this is possible?
Sim card plus esim two separate numbers on separate phones
Best answer by Daz_S
Hi there
No, not currently.
You can have 2 accounts and 2 different numbers, one on a SIM in phone ‘a’ and the other on an eSIM in phone ‘b’. You can however view both plans on just one phone if you’d prefer.
But don’t mention business use if you order, we’re not supposed to use iD for business use, but I won’t tell on you!
Log in to the iD Community.
