Text messages won't send or receive
Can’t send or receive any text messages. Been with ID for 2 years. No change to phone. Checked coverage in this area and all good. Tried turning off and on phone. Other family member having same trouble and ID too.
Justin's Id
  • January 16, 2021
I'm having the same problem. I've tried restarting, and switch off and remove sim. Nothing seems to help so far. Is this a network fault ?
Cornwall67
  • January 16, 2021
I'm having the same problem with my text messages too, can make calls ok just not messages.
C9745n36
  • January 16, 2021
I'm having the exact same issue! It's only today it's started, but nothing I've tried has fixed it..
LyndaMoonstone
I cannot send text messages, despite having a good connection. I can send Whatsapp messages and get onto the Net. Have tried installing updates but nothing helps.
  • 12 replies
  • January 16, 2021
I think it is a service wide issue as there are a lot of these posts today, I cant send either. Im waiting on the live chat now to find out
  • January 16, 2021
ID online chat have now said
We are currently experiencing a technical outage regarding sending and receiving text messages and calls.
We have escalated this to the technical team to have this resolved.
Kindly note that the issue started today and the technical team will do their utmost best to have this resolved as soon as possible.
I do apologize for the inconvenienced caused
  • 12 replies
  • January 16, 2021
I just got a similar reply too, thanks.
I do apologize for the inconvenience, Our technicians are aware of the issue and it should be resolved within 3 hours. If not please do contact us back
Shej
  • January 16, 2021
Same here. Just checked after trying all suggestions from Apple and realised it’s an ID technical issue. Will check back again. It’s been happening since 9.30am this morning.
Will
  • 4103 replies
  • January 20, 2021
Hi All,
We did have some network issues relating to the sending and receiving of text messages on Saturday, but these have since been fixed. Are you still having the same issue, or is it resolved now?
Will
Shej
  • January 20, 2021
All resolved now. Thanks Will.
S
Michelle
  • 1540 replies
  • January 24, 2021
Thank you for the update @Shej
