Using phone outside EU
What's the most economical way to use my phone in New Zealand? Will need to call both New Zealand numbers and UK ones. Thanks.
Best answer by Ryan
HI @Curlewpam ,
Calls to the UK and to a New Zealand number whilst over there would cost £1.68 per minute, texts would cost £0.42 and data is £0.30 per MB. Receiving a call would cost £1.50 per minute. We don't offer any Roaming Add-ons either so it could get costly.
As a bit of impartial advice, you might be best purchasing a local SIM card for your stay if needing to contact New Zealand numbers.
Further roaming charges can be found here. I hope this helps!
View originalCalls to the UK and to a New Zealand number whilst over there would cost £1.68 per minute, texts would cost £0.42 and data is £0.30 per MB. Receiving a call would cost £1.50 per minute. We don't offer any Roaming Add-ons either so it could get costly.
