Since shortening the ring from 30 to 20sec, voice mail not working - says number not recognised. Have tried all the suggestions on site and have been to Carphone warehouse they cant help, any suggestions.
voicemail no longer working after shortening ring time
Best answer by fauvehound
Hi EllaF
This worked for me and my daughter, hope it works for you the number required is +447782 333123 good luck
Sandra
Our Tech Team have asked if you can check your call settings on the handset. To do this, please perform the following actions:
Press the phone icon.
Press the menu icon.
Press Settings.
Press Call forwarding.
Press the required divert type.
Check all type of call forward and see if you have the correct Voice Mail number saved.
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
