Voicemail Notification that won't go away!
Since I've joined iD mobile, i consistently receive a voicemail notification message on phone despite not having any voicemail. I have ported my old number.
I've tried clearing the cache in my messaging & contacts app. Then resetting the phone.
I've tried leaving my mobile number voicemail to delete later.
None of these steps have worked.
Does anyone else have this issue or found a working solution ?
Best answer by Ryan D
This would work to remove the notification temporarily so it's worth a try if that is what you require. If you need a permanent fix, we would always recommend speaking to our Live Chat team in order to raise the issue as it can come about whenever you port your number at the same time as a voicemail message being received.
Log in to the iD Community.
Social Login
