voicemail pin
  • October 17, 2023
  • 735 views
Bobt
Is the voicemail pin that you use to access it abroad, the same as customer service pin? If not how do I find out what it is?
Yes @Bobt, if you’re in the UK, just dial 123 from your iD SIM and you’ll be connected to the voicemail service (provided and managed by Three, the iD Mobile network partner).
There’s a number options, including an option to manage the settings (PIN, etcetera) for your voicemail.
  • 12619 replies
  • October 17, 2023
The customer service PIN is not the same as the voicemail PIN @Bobt.
I think the PIN for the voicemail service has to be setup on the home network, not a roaming partner’s network. So you’ll probably need to be in the UK connected to the iD network, to work with the voicemail service and setup a PIN.
Bobt
  • October 17, 2023
Ok thanks @andewhite so I just dial the voicemail number and set it up on there?
  • 12619 replies
  • October 17, 2023
  • 8765 replies
  • October 18, 2023
Hi @Bobt
Thanks for the help on this one @andewhite.
