Voicemail says number not recognised check and try again
  • December 23, 2021
  • 1958 views
When someone calls my mobile when unanswered instead of voicemail they get the message the number is not recognised please check and call again.
I have been with ID for many years
not a new sim
not a new phone
no changes to any settings
happened in the last few days
happens with mobiles and landline calls from everybody
if I dial 123 voicemail tells me no messages
RG12 post code
I am a voluntary emergency Responder so it is quite urgent
  • 3045 replies
  • December 23, 2021
Maybe try disabling voicemail, wait a few minutes and then enable it again?
  • December 23, 2021
Turning voicemail off leaving for half an hour then turning back on did not work.
Removing and replacing the sim did not work either.
I think it is a network problem at ID’s end.
  • 3045 replies
  • December 23, 2021
Not got this issue on both of my pay monthly ID accounts.
Probably best speaking to a live chat agent as this will need account access to sort out:
  • December 23, 2021
I got to a chat “person” eventually but they were unable to fix the problem. I think they were working to a script, they have passed me to “technical”. They said leave 48 hours but with Christmas I think it is going to be a lot longer,
  • 7962 replies
  • December 23, 2021
Hello @Zebidee,
Weird that it’s just stopped working despite no changes.
  • December 24, 2021
I have managed to fix the problem.
There are various call handling settings such as “when unanswered divert to”  “when busy divert to” etc. all of these have the same number (provided by ID mobile) not the user.
One of these was missing several numbers in the divert, these are settings which a normal user does not touch and neither have I. They are set up when the sim is inserted so the problem must have been caused by an update or malfunction with the sim. Removing and replacing the sim did not correct the problem.
Perhaps these possibilities should be added to the list of items the chat staff use. Could you please de-escalate my problem.
Taye Stone
Helpful
  • Helpful
  • 74 replies
  • December 26, 2021
I was just about to say I bet that's the problem. Glad I could help
