WIFI Calling using Samsung A53 5G
Guzbry
According to ID mobile Wi-fi calling is supported.  According to Samsung, my A53 5G supports wi-fi calling.  However I cannot connect because the wi-fi Icon does not appear on my mobile.  Everything is up to date.  Any help would be appreciated as I live in an area where all mobile network signals aren’t reliable.
Best answer by Tom
Hi @Guzbry
Does no Wi-Fi icon show on your device at all when connected to Wi-Fi? Does it show 5G/4G/3G instead?
  • 12550 replies
  • November 21, 2023
Is the Wi-Fi Calling option turned on  your handset @Guzbry?
https://www.samsung.com/uk/support/mobile-devices/how-to-activate-wifi-calling-on-a-galaxy-smartphone/
Perhaps this online article might help.
Toby Field
Helpful
  • Helpful
  • 59 replies
  • November 21, 2023
Try turning airplane mode on and then WiFi and see if the WiFi calling symbol appears. For some reason, WiFi calling only activates on my Samsung S21 when the signal is very low when connected to iD Mobile. It would work continuously when on EE. Not ideal.
  • 12550 replies
  • November 21, 2023
It’s a pity iD Mobile don’t provide an option to prefer Wi-Fi Calling, which is available on many Android devices if you’re using the EE network.
Guzbry
  • November 21, 2023
Andewhite and Toby Field,  there is no Icon on my phone.  The link you gave me I had already checked, no help. Tried the airplane mode, that doesn’t work either.  I’m thinking that maybe Samsung lied???
Very frustrating.  Thanks for the responses.
  • 12550 replies
  • November 21, 2023
Perhaps iD Mobile don’t support Android Wi-Fi Calling with the A53 5G handset @Guzbry
Check online at https://www.idmobile.co.uk/help-and-advice/approved-handsets.
Scroll down to the Samsung section - the A53 is listed and NOT the A53 5G, which seems odd as these devices can’t be hugely different.
Toby Field
Helpful
  • Helpful
  • 59 replies
  • November 21, 2023
My wife has an A53 5G on O2. The iPhone supports it, maybe not the iD network then
  • 12550 replies
  • November 21, 2023
I know iD WiFi Calling works reliably on my son’s Pixel 6a and my daughter’s Galaxy S10.
Anyway, I switched from Android to iPhone in 2018 because all the UK mobile network operators (MNO) support WiFi Calling with iPhone handsets. iD Mobile might have been one of the first MVNO companies to offer a WiFi Calling service. I need a reliable WiFi Calling service in my mobile not-spot.
Perhaps operator support for iPhone WiFi Calling is better than on Android - possibly because of Apple’s huge share of the UK smartphone market.
  • 8584 replies
  • November 22, 2023
Hi @Guzbry
Guzbry
  • November 22, 2023
Hi Tom,  I spoke to Samsung earlier.  It would appear that I am ignorant of the way that wi-fi calling works!!!  When I called them the Wi-fi phone symbol appeared on my phone and then went off a minute later.  I was reliably informed that wifi only works when no or a very weak signal is detected.  Not a lot of good for receiving calls as I am still missing calls.  Contrary to a lot of the information available on the web the Wi-Fi calling symbol does not appear under wifi under Connections.  You have to click on the phone icon, click on the 3 dots and select ‘Settings’ and there you will see the wi-fi calling button which I switched on when I first bought the phone ages ago.  It does say use wifi to make and receive calls.
Why am I missing calls?
Thanks for responding and maybe you can answer the last question.
  • 12550 replies
  • November 23, 2023
Okay @Guzbry, in an ideal world there’d be a prefer Wi-Fi Calling option in the Android settings, but iD Mobile can’t / won’t provide this facility.
Check out the “A better way to use WiFi Calling” forum topic, which hopefully helps.
  • 8584 replies
  • November 24, 2023
Hi @Guzbry
In any case with us Wi-Fi calling would be selected automatically when it is the stronger signal, if your regular signal is stronger, that’ll be chosen. You shouldn’t be missing calls, have you tried with Wi-Fi calling off?
  • 12550 replies
  • November 24, 2023
Tom wrote:
Hi @Guzbry
The issue reported by @Guzbry, seems to be that the iD Mobile WiFi Calling service is not chosen automatically whenever the mobile network signal is very weak.
  • 8584 replies
  • November 27, 2023
Hi @andewhite
The device would automatically switch between Wi-Fi and standard network calling based on what it believes to be the stronger signal.
  • 12550 replies
  • November 27, 2023
Tom wrote:
Hi @andewhite
Okay, thanks @Tom.
Guzbry
  • November 28, 2023
Thanks for all the replies.  It would seem that this system needs  a major upgrade.  We should be able to make and receive wifi calls when we are at home.  Ideally our phone should switch automatically to wifi calling.  Currently there is a major problem regarding a poor signal and when the phone switches to wifi because I am missing calls.  Not good when you are self employed!  Also I can’t enter any telephone competitions.
I’m sure this is an easy fix but for some reason no one wants to do it!
Guzbry
Anthonygb
  • 18 replies
  • November 29, 2023
I have am Samsung handset also.
The only way you can guarantee a WIFI CALLING signal is to switch the phone into AIRPLANE MODE when you are at home and select WIFI CALLING enabled. I do this when I am at home to guarantee a strong signal. Ensuring the phone is connected the WIFI internet.
When I leave the house I just switch AIRPLANE MODE off and then selects the mobile mast signal when I am outdoors.
Its not just with ID MOBILE / 3…. I have had this issue with a Samsung handset on VODAFONE and EE!
  • 12550 replies
  • November 29, 2023
My spouse uses a Samsung Galaxy S10 on EE and has a setting to prefer Wi-Fi Calling, which works nicely.
If the carrier (mobile service provider) doesn’t provide a prefer Wi-Fi Calling option, perhaps best solution is to use the work-around described by @Anthonygb
