Wrong number still showing in messages after port?
I have successfully ported in my old number to my ID mobile sim but recently it has stated to show my temporary ID mobile number when I send a text to anyone.
Why is this?
Best answer by Mohammed H
Hello @Black-kite-13,
Welcome to the iD Community!
Is this an iPhone by any chance?
The culprit for this would be iMessage.
What happens sometimes is when you've ported your number, iMessage doesn't update to the new number and needs to be done manually.
Can you try the following;
1) Try turning off iMessage (Settings > Messages)
2) then restart your phone (by pressing and holding the on/off button)
3) tap Settings > Phone > My Number and confirm that it is correct.
4) If it is not correct, please enter the correct number)
5) then turn iMessage back to On (Settings > Messages)
6) go to Settings > Messages > Send & Receive and see if the correct number is displayed under “Start new conversations from:"
This should fix the issue you're facing (if it's an iPhone you're using)
EDIT: Duplicate topics merged to clean up the community.
Mohammed H
  • 7962 replies
  • May 28, 2018
  • May 28, 2018
Hi Mohammed, yes it is an iPhone, your solution has worked a treat and solved the problem.
Thanks for the full and clear answer, hopefully will be helpful to others.
Best Regards
Black-kite-13
Mohammed H
  • 7962 replies
  • May 30, 2018
Best Regards
Black-kite-13
That's great @Black-kite-13
I'm glad to hear this has resolved the issue!
Steved
  • June 19, 2018
I have sent my pac code over via the app. My phone number has now changed but when i text it is still under the old number. Any ideas ?
Mohammed H
  • 7962 replies
  • June 20, 2018
Hello @Steved,
Can you try:
6) go to Settings > Messages > Send & Receive and see if the correct number is displayed under “Start new conversations from:”
Let me know if this works.
Steved
  • June 20, 2018
All working 👍
Mohammed H
  • 7962 replies
  • June 21, 2018
Steved wrote:
All working 👍
Awesome!
Glad to hear @Steved.
Thanks for confirming this. 😄
Mark2020
  • December 9, 2020
My wife phone has ported her old number over to ID mobile it is a android Moto g 7. Do you know how to fix this, I've tried to Google the answer but not having much luck thanks
Kevin M
  • 2535 replies
  • December 19, 2020
Hi there @Mark2020
Could you have her turn the phone off, remove the SIM.
Then turn the phone on (without SIM) and leave it for about 4-5 mins or so.
Then turn off, re-insert the SIM, and turn back on.
That should hopefully cause the phone to refresh the number in the Android settings.
Let us know how you get on.
Mark2020
  • December 19, 2020
Thanks for the help it was the phone in the end 3g stop working. Bought a new phone and worked straight away ☺️. All is working great now
Kevin M
  • 2535 replies
  • December 22, 2020
Great to hear things are working at least now @Mark2020
If you need us again just get in touch here.
Merry Christmas.
Kingofcake
  • January 21, 2022
Hi i am having this problem for my phone its the google pixel 6 any tips
  • 8256 replies
  • January 23, 2022
@Kingofcake ,
Could you please try the below?
Change the phone number associated with the Messages app: Open the Messages app. Tap More More and then Settings and then Advanced. Select Phone number, then edit the number to the correct phone number associated with your SIM card. Tap OK.
  • February 10, 2022
i tried the following method above for iphone to fix the expiring number problem. whilst it fixed the issue of my temporary new number disappearing and registering my old number back onto my phone - my iphone still tells me my number is going to expire for imessage and face time? is there anything else i can do?
  • 8256 replies
  • February 13, 2022
Hi @ch44rlies,
It may be worth turning the handset off and removing the SIM for a few minutes.
Please reinsert the SIM and restart the handset and try changing the number.
If the issue keeps persisting it may be worth contacting Apple directly for further assistance.
  • May 11, 2022
Hi, I hope someone can help me.
I have recently purchased 2 new Samsung A53 5G phones, I've ported my numbers and both phones still send messages to certain numbers with the number that came with the phones.
Rory C
  • 1684 replies
  • May 18, 2022
Hi @Alan F. have you tried turning Chat Features off and on?
  • Open Messages.
  • Tap More options > Settings > Chat features.
  • Turn Enable chat features OFF, wait 15 minutes, restart the phone, and turn them ON again
If that doesn’t work, I’d recommend contacting the FacebookTwitter or Live Chat teams for further assistance.
Rory
  • May 18, 2022
Hi Rory,
I switched the chat feature off and back on after 15 mins that didn't work so I tried again but turned phone off when switched chat off then switched phone on and turned chat feature back on and that seems to of done the trick
Than you
Alan
Rory C
  • 1684 replies
  • May 19, 2022
Thanks @Alan F, my post did say to restart the phone, so I’m glad this worked for you! :)
Rory
Ray Mcconnell
  • October 17, 2023
Very sm
Kevin wrote:
Hi there @Mark2020
worked for me on Pixel  3 XL. Thanks
  • 8552 replies
  • October 20, 2023
Hi @Ray Mcconnell
Glad to hear the above helped you out here.
TomCat Montgomery
Right I've just had this problem with my new pixel 8a
Ive spoken to 3 id mobile agents and an assistant in Currys.  Not one of them knows how to fix it. So they are sending me a new SIM.
How ever my son fixed it in seconds.
So here's how to to it.
Go to phone settings.
Type in RCS CHATS  then on the next page click on RCS CHATS  , should be at the top.  On the next page there will be a toggle to turn off that says turn on RCS chats.  It will be on so turn it off wait a minute and turn it on it should then ask you to verify your number. So type in the number you want to use and it will connect and be fixed.
Im Hoping the id mobile assistants read this so they actually can help there customers as they've been useless today.
  • 8552 replies
  • June 10, 2024
Hi @TomCat Montgomery
Thanks for the suggestion, I can see this suggestion has been made above, glad to hear this has been sorted for you.
  • June 15, 2024
I have followed the instructions as per the above for an iPhone and still nothing. Whenever I change the number on phone and click save, it reverts back to the old number immediately after. Any ideas?
  • 5223 replies
  • June 17, 2024
Hey there @Elliekitty, we’re sorry to hear that.
Please try resetting your network settings first, and then following the below instructions:
Sometimes resetting the network settings first, then following the instructions above can kick it into gear.
Let us know how that goes.
