wrong phone number on device info Iphone
Graham Cronshaw
I transferred my number from EE but was given a temporary number when I set my new phone up.
For some reason the temporary number is stored against the phone in device info meaning I get an irritating “message failed to send” message for every text sent although they do go through. I can’t simply just edit the number and it is driving me crazy!
Has anyone found a fix for this?
Best answer by WelshPaul
Perform a ‘Network Reset’ @Graham Cronshaw. How you do that depends on what device your using.
  • 3087 replies
  • March 9, 2024
  • March 11, 2024
Hi @Graham Cronshaw,
As @WelshPaul mentioned please try a network reset, if that doesn’t fix the issue please let us know the handset make and mode so that we can guide you through other steps.
  • October 26, 2024
Hi, I have the same issue after porting my number
iPhone 16 pro max
can you advise please
  • 4825 replies
  • October 28, 2024
Hey there @Paul D 1971, please try the following:
