My daughter is in south east Austria (Turracher Höhe) with an ID mobile SIM card in her phone. She flew into Slovenia where her mobile signal was fine but she has had no signal either on her travel to resort or whilst in resort (journey to resort was about 2 hours).
Are there problems with Id mobile partner networks in this area?
Austria roaming
Best answer by Kevin M
Hi @Arrow77 .
In Austria, you would want to be connecting to the 3 network.
Your daughter may need to manually enter some APN settings within her network settings on her phone.
Be sure to delete any old profiles or settings from a previous network first, then enter the following:
APN: id
Username:
Password:
MMS Proxy: mms.idmobile.co.uk
MMS APN Username:
MMS APN Password:
MMS Port: 8799
View originalIn Austria, you would want to be connecting to the 3 network.
APN: id
Username:
Password:
MMS APN Username:
MMS APN Password:
MMS Port: 8799
Log in to the iD Community.
