Mobile Data not working
My Mobile data does not work on my Phone. The system shows I have rolled over my usage but it just does not work. I have had no problem with my previous provider and I have only been with ID since December. I live in the south east of England.
Best answer by johnkeywood
Hi, I have reset my phone back to default settings and it works.
Thank you for your help.
View originalThank you for your help.
Log in to the iD Community.
Social Login
