My mobile data is not working for the Internet I have a Sony Xperia L3, I have tried everything that is suggested and its still not working
Â
Best answer by Lizzyx9
View originalMy mobile data is not working for the Internet I have a Sony Xperia L3, I have tried everything that is suggested and its still not working
Â
View originalHi
Has your data ever worked?
Do calls and texts work ok?
We’d recommend you restart your phone, make sure mobile data is activated and WiFi is off.
Â
If that still doesn’t work and other services are unaffected, you can check the APN settings on the phone as reset them if necessary.
Let us know what you find.
Â
PhilÂ
Hi Phil,
yes I restarted my phone and it all works perfectly now, thank you, I didn't realise it would be that easy lol
