Very poor data upload speed.
  • February 24, 2021
  • 85 views
Just signed up to ID mobile as it uses the Three network. In my house there is no fibre broadband but we do get a good 4g connection with Three.
When I run a speed test on Three and ID in the same location, I am only getting 0.5mb upload from ID but over 9mb with Three. I need a good data upload for screen sharing. How can this be improved?
Ryan D
  • 4571 replies
  • February 24, 2021
Hello @WildsideUK,
There is no option on our side to improve upload speeds I’m afraid. We would recommend trying the connection in different areas/rooms to see if this makes any difference; we’re not sure why you are getting higher speeds on Three as we do use the same network.
Were both tests on that app done using the same connection server?
  • February 24, 2021
Yes, both on the same server. It just seems to be a huge difference for no reason, the signal strength is the same.
