Recently moved to ID, phone says 4G but can never get an internet connection. Any ideas?
4G connection?
Best answer by Lauren
It’s possible that 3UK is not as strong in your local area which could be why the coverage is affected. If it’s occurring everywhere you go, the issue points more likely to a handset or SIM fault.
However, from your screenshot, this suggests that this is a temporary local outage. Just so that you’re aware, the website itself updates every half an hour with any new information, and will let you know once the issue has been resolved if this hasn’t been rectified already.
-Lauren
Reply.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
