5G connection so slow
No matter where I am, my 5G is SO slow. It used to be fine at home but after the last week or so, it’s dropped down to barely being useable. It’s saying there’s no network issues in the area but I just cannot believe that?
Best answer by WelshPaul
That has to be the lowest 5G speed test result I have ever seen! Have you entered your postcode in to iD Mobile’s network status checker to confirm if there are any issues reported with your local mast? If not, you can do that using the link below:
In the meantime, maybe try disabling 5G on your device then try running a speed test using 4G. This might return better results at least until you can figure out what the cause of those low 5G speeds.
  • 2895 replies
  • July 12, 2024
  • 3978 replies
  • July 29, 2024
Hey there @Ct326, welcome to Community!
We're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know.
