Are iPhones compatible with mobile data on id mobile?
  • August 23, 2024
  • 72 views
Sean Dockerty
Just moved from Lebara to I’d mobile and now my “Mobile Data Settings” are missing from the “Mobile Services” tab. They were there on Lebara but now I cannot access the internet via 4g. Looking through the community it seem that these options are blocked or not enabled on iPhones.
Any idea if this can be fixed before I cancel my account.
iPhone XR. IOS 17.5.1
Sean.
Best answer by Matthew T
Hey @Sean Dockerty,
You should have a “Voice & Data” option. If you’re phone isn’t connecting to 4G, it might be worth doing a NETWORK SETTINGS RESET to clear any configurations from Lebara.
  • 1996 replies
  • August 27, 2024
Hey @Sean Dockerty,
Sean Dockerty
  • August 27, 2024
Would you believe it, done it and all connecting. Thank you. Tabs still missing but it works so all good.
Many thanks,
Sean.
