Call transfers while abroad
  • January 7, 2025
  • 140 views
I am in Tanzania for two months with a local SIM card and my mobile only takes one.
UlI would like my calls in the UK to my number 07792 211839 to be automatically transferred to my Tanzania number.
Is this possible?
Best answer by Natalie W
Hello ​@Bike For Life
Thanks for getting in touch with us here on the community.
You are able to set up a call forwarding rule if you wish to divert calls from your iD Mobile number.
We would also recommend setting up a spend cap on the iD account to limit any charges that occur due to this.
Nat
Forum|alt.badge.img+21
  • 2255 replies
  • January 10, 2025
Nat
