calls not working
Aziz Ur Rehman
I switched my number from o2 but my calls are not working. Data and text are working.
Aziz Ur Rehman wrote:
is there a contact number that I can call on? My phone calls are still not working and I can’t seem to get through to a customer service person on live chat
Unfortunately @Aziz Ur Rehman, iD Mobile only provide online help & support for their customers.
Try telling the 24/7 iD chatbot you’d like to “talk to a person” - do this a few times though.
The iD advisers work 9am - 8pm on weekdays.
Otherwise, try sending iD support a private message using Facebook Messenger.
  • 12433 replies
  • June 12, 2024
Have you tried a NETWORK RESET on the handset with your iD SIM, @Aziz Ur Rehman?
Aziz Ur Rehman
  • June 12, 2024
Yes I did and it’s still not working
  • 12433 replies
  • June 12, 2024
What date did you select for your number switch, @Aziz Ur Rehman?
Is your old O2 SIM card inactive now?
Aziz Ur Rehman
  • June 12, 2024
I switched today
Aziz Ur Rehman
  • June 12, 2024
Yes my old sim is inactive
  • 12433 replies
  • June 12, 2024
Sometimes number ports to iD Mobile aren’t completed properly until 10pm on the switching date, @Aziz Ur Rehman.
Forum members like us can’t see customers accounts.
Maybe ask iD customer service for a status update from https://idmobile.co.uk/live-chat.
Aziz Ur Rehman
  • June 13, 2024
  • 12433 replies
  • June 13, 2024
Aziz Ur Rehman
  • June 13, 2024
It’s sorted.
I got through to a customer service person and he told me to go to settings> phone> my number and delete my old number and type my new number there and save it. Restart the phone and it worked for me.
Tom B
  • 8408 replies
  • June 28, 2024
Hi @Aziz Ur Rehman
Glad to hear you’re sorted now.
  • June 29, 2024
Hi I’m new user. I’m using iPhone 12pro max. One international number with physical sim and always works and shows full signal. But I’m using id in esim. It’s always show empty signal bar for id. But I can use internet. I never received an incoming call. But if I have to call just dial the number then automatically all signals full and I can make call after cutting call then all signal run away from phone. So no one can call me.  How to fix it. Thanks
  • 4697 replies
  • July 12, 2024
Hey there @anilbidhan, thank you for reaching out.
Are you still having the same issue please?
