cant ring out or receive calls all of a sudden
  • December 31, 2024
  • 9 replies
  • 385 views
Lana Morgan
Woke up today can't make calls or receive them what's going on? Yes checked phone what now?
  • December 31, 2024
Hi ​@Lana Morgan,
Have you restarted the phone and reset your network settings?
Are you other services working? It sounds like it may be an issue in the area and I would advise checking the Network Status at the link below:
https://www.idmobile.co.uk/help-and-advice/coverage?srsltid=AfmBOoo_3lm9S17OCNm_n7-uv3LDtefhL20TSB-7H9Vb03rQaiIZDIGJ#coverage-info
Decembersangel72
Silver Contributor
Forum|alt.badge.img+12
Hi ​@Lana Morgan
What phone do you have?
Has the 3G network been turned off in your area?
Can you see if VoLTE is enabled on it? You need to see LTE as the connection type to be able to use the 4G network as it uses VoLTE (Voice over LTE).
If you need to find out how to check/enable VoLTE on your phone then Google (other search engines are available) is your friend!
Lana Morgan
  • January 1, 2025
Yes have checked all that and my phone has all this working on 4G just calls in and out
  • 8408 replies
  • January 1, 2025
Hi ​@Lana Morgan
How are texts and data?
What happens when you try to make a call?
Have you joined us recently?
Decembersangel72
Silver Contributor
Hi ​@Lana Morgan
When you say ‘my phone has all this working on 4G’ do you mean that you see ‘4G’ in your network mode settings?
Texting and data work over the 4G network but calls (making and receiving) need to connect to the VoLTE (LTE) network so you need to see LTE in the network mode  and have VoLTE enabled
If you let us know what phone you have then maybe we can be more specific in the answers.
x x
  • January 23, 2025
What's going on today I could make calls untill 3pm today nothing happening now can't make or receive calls can make calls on WhatsApp internet still working
  • 12403 replies
  • January 23, 2025
Seems Three UK have a problem with voice calls on their mobile network, ​@Ian rogers
Consequently, any of the MVNO business using Three UK might have issues too.
  • January 23, 2025
I'm unable to make or receive calls been like this since 4pm today. Data seems to work but normal voice calls
Can't get into the app either. What's going on??
  • 4266 replies
  • January 24, 2025
Hey there ​@Greggs
We're aware of a network wide issue that was affecting services, and we believe this has now improved for most customers, so please restart your phone and attempt to call. We sincerely apologise for any inconvenience caused, and really appreciate your patience.
Updates can be found here:
https://community.idmobile.co.uk/contacting-id-183/we-are-aware-that-some-customers-are-experiencing-issues-making-and-receiving-calls-72269
