Connecting to wifi
Forum|alt.badge.img
I have just started a new contract with ID mobiles today.  The switch went fine but not connecting to the wifi despite it appearing that it has connected.  I turned the mobile off and when I switched it back on there was a connection for about a second before it disappeared.
Any suggestions
Best answer by jmculpin
Thank you for the helpful responses.  Finally worked out the issue was due to VPN.  Once I disabled VPN on the new phone my internet connected
  • 12531 replies
  • June 3, 2025
Okay ​@jmculpin, does this happen with just one Wi-Fi network, or is the same happening whatever Wi-Fi network you try?
Forum|alt.badge.img
  • June 3, 2025
I’ve only tried it with my wifi at home.  My laptop is connecting fine
  • 8484 replies
  • June 4, 2025
Hi ​@jmculpin
I’m sorry to hear this, what device are you using?
I’d recommend trying another Wi-Fi network, if possible.
Forum|alt.badge.img
  • June 4, 2025
  • 5144 replies
  • June 4, 2025
We’re glad to hear all is sorted ​@jmculpin!
