currently not receiving or able to make calls
  • September 14, 2024
  • 90 views
Puddled69
Currently I am unable to make or receive calls.  WhatsApp, messenger and Snapchat are working fine.  Any suy
Best answer by Lauren
Hi @Puddled69, this sounds like the issue is in relation to our 3G switch off.
If you’re using an android device, ‘VoLTE’ will need to be enabled/toggled on in the device settings to allow 4G calling.
More information on this can be found via the link below:
3G is being switched off. What do I need to do? | Join the discussion, ask questions, share advice. (idmobile.co.uk)
-Lauren
Lauren
Forum|alt.badge.img+19
  • 479 replies
  • September 17, 2024
-Lauren
