data connection
Geoff Robotham
I can make calls but data connection now almost none existent. I get a connection about 10% of times but mostly nothing despite having 4g and four bars for signal. It has gotten progressively worse over the past six months. I have tried all the usual fixes but none of them seem to be the problem. Has the signal been down graded recently?
it’s infuriating!
geoff
Maybe @Geoff Robotham
Check online at https://www.three.co.uk/support/network-and-coverage.
  • 12167 replies
  • June 3, 2024
Geoff Robotham
  • June 3, 2024
Thanks. It may be the switching off of 3G that’s doing it. Otherwise there a lot of “maybe” factors that affect coverage!
cheers
  • 8175 replies
  • June 10, 2024
Hi @Geoff Robotham,
Have you checked the coverage and network status checker?
If you would like us to take a look into the issue, please let us know and we can PM you.
  • June 11, 2024
I'm having the same issues. The Three network checker says "We're working on the network I this area" could this be the issue? If so, is there anyway to see how long it's expected to be? Data is completely unusable all around town
  • 12167 replies
  • June 11, 2024
Works is probably connected to the Three UK (the iD network partner) 3G shutdown happening across the UK by end of 2024, @Hillt96.
Personnel could be working on cell towers / backhaul network in your area for a period of time. When the Three UK network is congested, they use TrafficSense system to manage bandwidth, which might happen while this works is ongoing.
