Data isn't working
My Internet does not work properly..I have tried everything including restarting, off,/on, flight mode etc. the pages often don't load and if they do it takes ages. Whatsapp messages don't send either..they may send after an hr or so. New to id mobile.. thinking it's all a scam..100gbm of unusable data!!!
Best answer by Kash
Hi @Idareuseless34 @Aneesa,
Sorry to hear about the issues that you have experienced.
I would advise checking out the Help Hub article below:
If you still have issues please let us know.
Honestly everyone is in the same boat looks like there's nothing we can do other than leave when the contract ends, hopefully they go bust, absolute con, now I know to just pay the little bit extra for a known provider
  • June 4, 2024
Seriously..is there anyone we can complain to???
  • 12167 replies
  • June 4, 2024
Maybe try online at https://www.idmobile.co.uk/help-and-advice/complaints-procedure,  @Aneesa.
  • 8175 replies
  • June 11, 2024
  • June 20, 2024
I have figured out how to work it! First off go onto Mobile data in settings then cadd your number to your esim that doesn't have a number and add your number then change it to your primary data then delete your old sim off your phone and it should work
