Divert calls
If I divert my ID mobile number to a vodaphone number will I be charged and if so, how much will it cost?
Best answer by Phil H
Hi JTD, calls diverted will be charged at the normal call cost so calls diverted to another UK network would be included in your monthly allowances and then 40p/min outside of this.
-Phil
View original-Phil
Log in to the iD Community.
Social Login
